Bryonmax 0 Posted May 26, 2012 Hi Folks, small problem, in need of some help. When ever I plug in the cutter, the cutter-head goes to the end of the track and makes a terrible noise for about 5 seconds. What can I do to fix this, thanks Model: USCutter MH871-MK2 Share this post Link to post Share on other sites
cowboy_1_831 28 Posted May 26, 2012 Is the cutter head off track by chance. Share this post Link to post Share on other sites
Dragonduster 4 Posted May 26, 2012 check it is on the rail, when mie came, it was off track and made a lot of noise AND cuts were terrible Share this post Link to post Share on other sites
Bryonmax 0 Posted May 26, 2012 Its cutting pretty decent but its just that start up noise. The head automatically goes to the right by default when the cutter is powered on, that is where the problem is, when it reaches the end it just makes a whole heap of noise for about 4 to 5 seconds Share this post Link to post Share on other sites
Snapper 30 Posted May 26, 2012 Its cutting pretty decent but its just that start up noise. The head automatically goes to the right by default when the cutter is powered on, that is where the problem is, when it reaches the end it just makes a whole heap of noise for about 4 to 5 seconds I'll bet the metal strip the holds the belt end to the head is running into the cog sprocket. Do not recall the fix at the moment... but was either adjust the limit switch or adjust the head on the belt. But one or the other fixes it. Share this post Link to post Share on other sites
Bryonmax 0 Posted May 26, 2012 Found it, slight manufacturers fault where the head braces on the body of the cut off switch before forcing itself past that point and then activates the switch to stop the track from sliding. Thanks, your info about the track being off made me look at that area Share this post Link to post Share on other sites
Bryonmax 0 Posted May 26, 2012 Slightly tapped the limit switch back a bit and it fixed the problem, thanks again Share this post Link to post Share on other sites
slice&dice 2,451 Posted July 1, 2012 +++ Bumping the thread +++ Many people have asked here on the Forums if these MH cutters are good units. Bryonmax, (if you are still following this topic after you've overcome a slight out-of-the-box glitch), would it be possible to share your experience over the past month in using the MH machine? Provide some further feedback and give some of your impressions, it would be appreciated, I'm sure. Share this post Link to post Share on other sites
