Andrew 2 Posted May 25, 2012 I have a f550 template that won't import into singblazer without messing it up. Any suggestions? Share this post Link to post Share on other sites
Jay2703 704 Posted May 26, 2012 How does it mess up? Can you post the file? Share this post Link to post Share on other sites
Andrew 2 Posted May 28, 2012 This is what it looks like in AI. And this is what it looks like when i import it into SB. I still need to save it as illustrator 8 or lower to get it to import into SB right? I'm trying to use it for size so when i make my design it cuts it out to fit... Share this post Link to post Share on other sites
Andrew 2 Posted May 28, 2012 Ok maybe im a little confused on how to use these car templates. I thought you open them in AI and everything was scaled out to the size of the vehicle. The more i look at it the more it don't even look scaled out right in AI. Here is my file.. Aurora towing.zip Share this post Link to post Share on other sites
Jay2703 704 Posted May 29, 2012 This one looks like it's 1/25th scale. Share this post Link to post Share on other sites
Jay2703 704 Posted May 29, 2012 Did you save it out as .eps version 8 to import into SignBlazer. Share this post Link to post Share on other sites
Andrew 2 Posted May 29, 2012 This one looks like it's 1/25th scale. what does that mean this is my first time using car templates. And yes I did that and tried it as a .ai file. Share this post Link to post Share on other sites
Rodger 527 Posted May 29, 2012 It is 1/25th the actual size . Popular model car size btw . You would take what you designed & make it 25 times bigger to fit a real car with the same perspective . ex : 1/2 scale car ... if the decal is 4' X 8" & that is the look you want , you would make it 2 times bigger to duplicate it on a real car . 1 Share this post Link to post Share on other sites
Andrew 2 Posted May 31, 2012 It is 1/25th the actual size . Popular model car size btw . You would take what you designed & make it 25 times bigger to fit a real car with the same perspective . ex : 1/2 scale car ... if the decal is 4' X 8" & that is the look you want , you would make it 2 times bigger to duplicate it on a real car . ok thank you. Share this post Link to post Share on other sites
