laserman70 2 Posted February 16, 2008 OK I am saving my work as an .eps in Illustrator. When I open it in signblazer, all i get is a blank page. Am i doing something wrong? I hear that vectormagic will be gone soon so i need to figure this out. I have version 6.021 with signblazer and CS3 in illustrator. Thanks for the help. Gregg Share this post Link to post Share on other sites
bk2design 1 Posted February 16, 2008 save your illustrator file as a version 8 eps and then import "use full postscript interpreter" Share this post Link to post Share on other sites
laserman70 2 Posted February 16, 2008 save your illustrator file as a version 8 eps and then import "use full postscript interpreter" thank you, I appreciate the help it worked yahoooooooooo. thank you Share this post Link to post Share on other sites
dustinjtrr 0 Posted September 18, 2008 the other thing I have found that works is to highlight and "copy" (ctrl+C) and just paste in signblazer. sometimes it just shows as a block but if you click one of the resize points it shows up fine. Share this post Link to post Share on other sites
snlsd 1 Posted September 18, 2008 Is there any way to convert AI files to EPS? I found a few files online and within this forum that were only posted as AI files. Share this post Link to post Share on other sites
ralais 0 Posted September 18, 2008 I tried the saving as "8" & that didn't work for me... any other ideas? Share this post Link to post Share on other sites
charlie_b CFXPaintworks 1 Posted September 20, 2008 To save as an EPS, you must got to File, then EXPORT as EPS. Then i would save it as an EPS 8 or lower. Hope this helps. Share this post Link to post Share on other sites
Guest Terry Posted September 20, 2008 save your illustrator file as a version 8 eps and then import "use full postscript interpreter" what bk2 said Share this post Link to post Share on other sites
Jay2703 704 Posted September 20, 2008 If you don't have Illustrator, you can drag and drop it into a Word document then copy and paste it into SignBlazer Share this post Link to post Share on other sites
stickyicky612 0 Posted October 15, 2008 why do we have to save as eps 8 i have cs3 and i just save it as eps whats the differnt? Share this post Link to post Share on other sites
