kdrifter440 0 Posted February 15, 2008 is there anyway to print to my laserpoint with draw x3? I don't see any drivers on uscutters? X3 three does not see my cutter Share this post Link to post Share on other sites
mustangconv85 0 Posted February 16, 2008 you need a program that will run the cutter try downloading the trial version of signcut x2 here http://www.sc-x2.com/free_trial.html then you can export your file from corel to signcut and then cut it Share this post Link to post Share on other sites
dgreenh 9 Posted February 21, 2008 I haven't found a way to cut directly from X3. I just use the application launcher and send it to signcut. There are some Corel drivers floating around but I don't think they work with X3. I haven't felt the need to pursue it since signcut is simply a cutting program that interfaces well with Corel X3 Share this post Link to post Share on other sites
