Robert76 1 Posted March 13, 2012 What Vinyl works best on stone that won't blast off from a sandblaster? Share this post Link to post Share on other sites
Robert76 1 Posted March 13, 2012 Or is there some thiing else i can add like a added glue ? Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted March 13, 2012 Look here http://www.uscutter.com/Sand-Blast-Mask-52 but i also hear any vinyl will work with blasting. Hope this helps 1 Share this post Link to post Share on other sites
Robert76 1 Posted March 14, 2012 Thank You One Off Grafx thats what i was looking for. have had my cutter for almost a month now so glad i that was exactly what i was looking for. 1 Share this post Link to post Share on other sites
Rodger 527 Posted March 14, 2012 Even if you are carving 1/2" or more into rock , glass etc .. you don't blast at the tape/vinyl line for long or directly . Most any vinyl should work & I think the temps & how clean the stone is makes more of a difference than material . Duct tape would be the max adhesive/durable stuff to use . You could find some wider duct tape & put it on a backing paper if reg vinyl won't work for you . Edit ; I use oracal 651 for all the etching I do . It holds up great for me . Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted March 14, 2012 You are welcome. There is also a site called BREN that sells some heavy duty mask and stencil material but you pay for it a 24" x 50 yard roll of stencil material ran me like 200. they try to get you to buy their cutters but all you have to do is set the blade depth deeper hi down force and 2 or more passes. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted March 15, 2012 Hello and welcome. Dan Share this post Link to post Share on other sites
