mfatty500 455 Posted September 25, 2011 How do I uninstall CS5 trial version? I get something that say Bridge is open but cannot find out how to close it out so that I can uninstall the trial version. Thanks Mike Share this post Link to post Share on other sites
AshComputers 197 Posted September 25, 2011 Have you uninstalled all of CS's suite? You have to uninstall everything before you do the bridge uninstall. It uses those files and you can't delete it until they are all removed. Any program like Photoshop will use Bridge, and has to be uninstalled before you can uninstall Bridge from your machine. Also, if you try to force remove Bridge (ie. -remove) before the other programs are uninstalled, you may find yourself with an error and/or a no booting machine Let me know if you've tried this. Hope this helps Share this post Link to post Share on other sites
mfatty500 455 Posted September 25, 2011 Have you uninstalled all of CS's suite? You have to uninstall everything before you do the bridge uninstall. It uses those files and you can't delete it until they are all removed. Any program like Photoshop will use Bridge, and has to be uninstalled before you can uninstall Bridge from your machine. Also, if you try to force remove Bridge (ie. -remove) before the other programs are uninstalled, you may find yourself with an error and/or a no booting machine Let me know if you've tried this. Hope this helps The only thing I have is CS5, and adobe reader no photoshop or any thing like that. Thanks Mike Share this post Link to post Share on other sites
AshComputers 197 Posted September 25, 2011 The only thing I have is CS5, and adobe reader no photoshop or any thing like that. Thanks Mike Have you uninstalled the whole suite? Share this post Link to post Share on other sites
