jwalters69 0 Posted September 23, 2011 With everyone's advice here (thanks) I purchased an Epson WF1100. Love the print quality. I am having trouble though contour cutting with sign blazer. Here is what I am doing: 1. take color graphic or text that I have cut in the past. 2. Printed in SB with crop marks in each corner. placed print in cutter. 3. Picked Cut a print in SB 4. followed on screen directions and moved cutter to crop marks as stated on the screen 5. Hit cut then either nothing happens or it does all the cutting on first .5 inches of print.... What am I doing wrong? I know SB is probably not the best software to do this but I am assuming it can be done. Can someone help me get this done then once I am comfortable at it what would be an affordable software to do these decals. i have a p-cut that I have had for over a year and can do cut vinyl no problem.. Thanks. Jim Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 23, 2011 a regular P-cut vinyl cutter is not capable of contour cutting with Signblazer CUT a Print. . You need a laser pointer vinyl cutter to use with the Signblazer to contour cut. http://www.uscutter.com/USCutter-LaserPoint-Vinyl-Cutter-w-CONTOUR-CUTTING-Feature-CRCLP24ST Share this post Link to post Share on other sites
jwalters69 0 Posted September 26, 2011 Will it work with other software? Or can you not countour cut with the P-Cut regardless of software? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 26, 2011 You can purchase Flexistarter 10 from UScutter or other vendors http://www.ebay.com/itm/Flexi-Starter-10-vinyl-cutter-FlexiStarter-Design-NEW-/270823332414?pt=LH_DefaultDomain_0&hash=item3f0e541a3e Share this post Link to post Share on other sites
