BroncoJim 0 Posted September 12, 2011 Hello to all, Im Jim, I am starting a new business doing sand carving and im looking for a cutter to make stencils with. Im sure there are some of you that cut this type of material, so I need some advice on Cutters. Im looking to cut with Anchor #123, #125,#116, #T226, #T227 and some others. I have never used one of these cutting machines before, so I have no idea how small a character each will cut thru thick material. Most of the work I will be doing will be medium size lettering, but I will also have alot of graphics with fairly fine lines. Most of these cutters have a 400g downforce, is that enough for thicker material? Most say 1mm thickness limit, that would limit me to 39 Mil thick masks. I suppose that is sufficient since most of the material I have priced is well below that. I assume if the machine handles thick material well it will do an even better job on thin material, is that correct? Ive seen some that require use of a back board (dunno if thats what you call it) for cutting thin material. ANy suggestions would be appreciated. THanks Jim Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 13, 2011 I am thinking there might be a "Sand Carving" forum somewhere else that might better discuss the subject.... Share this post Link to post Share on other sites
Rodger 527 Posted September 13, 2011 search sandblasting here . only difference is you stay away from the vinyl stencil while you blast deeper in some spots . I watched it at the Baltimore sign show this past weekend . Like Roxy says , there should be more experienced carvers available on other forums . Any cutter can cut vinyl which is what is used as a stensil . Any vinyl works for a stencil . Share this post Link to post Share on other sites
