windows 6 Posted April 26, 2011 Here a tank TANK.SBD Share this post Link to post Share on other sites
mark-s 1,126 Posted April 26, 2011 Why don`t you post an EPS so every one can use it. mark-s Share this post Link to post Share on other sites
mr300s 1,272 Posted April 26, 2011 Why don`t you post an EPS so every one can use it. mark-s tanks also tank.EPS Share this post Link to post Share on other sites
windows 6 Posted April 26, 2011 Sory mark dont know how to change to eps Share this post Link to post Share on other sites
BearlyRich 167 Posted April 26, 2011 If you want an eps file from Signblazer, simply select the graphic, go to the file menu and export it. At the bottom of the export window, you can select the type of file. Mine comes up with eps selected normally. Share this post Link to post Share on other sites
stickies 0 Posted April 27, 2011 Does that work in Flexisign do you know ? I'll try it out i think, i had no idea you could do that ! Thanks BearlyRich ! If you want an eps file from Signblazer, simply select the graphic, go to the file menu and export it. At the bottom of the export window, you can select the type of file. Mine comes up with eps selected normally. Share this post Link to post Share on other sites
BearlyRich 167 Posted April 27, 2011 If I could give back half the help I've received here, there'd be a whole lot of happy people Share this post Link to post Share on other sites
stetson5331 80 Posted April 27, 2011 Does that work in Flexisign do you know ? I'll try it out i think, i had no idea you could do that ! Thanks BearlyRich ! I have Flexi Sign Pro and yes it does in my version... Share this post Link to post Share on other sites
stetson5331 80 Posted April 27, 2011 If I could give back half the help I've received here, there'd be a whole lot of happy people I absolutely agree with you Bearly..I have gained so much from this Forum that I could never repay it all.. Share this post Link to post Share on other sites
