sjane_xoxo 0 Posted April 18, 2011 Hi anyone know of any programs that work with Windows 7? We have a ct630 and use Flexi Pcut edition but its just soo hard. Does anyone know if any of the other programs will work? I know SBE wont so just thought Id ask. Sara-Jane Has anyone tried using XP mode in windows 7?Just read about this option. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 18, 2011 Hi anyone know of any programs that work with Windows 7? We have a ct630 and use Flexi Pcut edition but its just soo hard. Does anyone know if any of the other programs will work? I know SBE wont so just thought Id ask. Sara-Jane Has anyone tried using XP mode in windows 7?Just read about this option. sbe works on my windows 7 with no problem Share this post Link to post Share on other sites
sjane_xoxo 0 Posted April 19, 2011 sbe works on my windows 7 with no problem Are there any tips or tricks? I had it on the correct port but then the cutter wasnt getting any info. All was set up as normal using the USB Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 19, 2011 no - worked fine here Share this post Link to post Share on other sites
racinboy30 9 Posted April 23, 2011 Are there any tips or tricks? I had it on the correct port but then the cutter wasnt getting any info. All was set up as normal using the USB Do you have the driver installed correctly, I use windows 7 pro as well, I have had no issues with it. Share this post Link to post Share on other sites
sjane_xoxo 0 Posted May 5, 2011 Do you have the driver installed correctly, I use windows 7 pro as well, I have had no issues with it. So I should check tp see if there is a windows 7 driver or would the other driver be ok? Share this post Link to post Share on other sites
