BigcockGraphics 0 Posted April 15, 2011 I was interested in starting t shirt printing I currently have a vinyl decal business and was wondering if I can just use the vinyl cutter to cut tshirt vinyl and if so what else I need to get started? Thanks for any useful information! Share this post Link to post Share on other sites
AshComputers 197 Posted April 15, 2011 1. Heat Press- Get a clam press!!!!!!! 2. Siserweed Vinyl 3. T-shirts heehehehe I'm sure some have more to chime in on this! Hope this helps Share this post Link to post Share on other sites
Sue2 920 Posted April 24, 2011 The easiest way for you to get into the t-shirt stuff is with the heat transfer vinyl. If you cut your own vinyl decals, you already know how to design for the cutter... cutting heat press vinyl is similar. Weeding is the same...if anything, the heat press vinyl is a bit more forgiving. Just remember to MIRROR your designs...most everything is cut in reverse for pressing on t-shirts. A good heat press is the only thing you will need immediately. NO, you can't use an iron! Get some Sisser or Thermoflex Plus vinyls...pick up some discount t-shirts at your local DollarStore or discount outlet and make up some funny samples. Heat press vinyl is great for small quantities...it is labor intensive but the results are nice and it holds up well. For small orders, you can usually find Jerzee t-shirts at craft stores on sale 2 for $5 or 5 for $10. For larger orders, set up an account with a garment/stuff supplier and sell them shirts! The first question out of your customer's mouth will be: "How much are your shirts?" Decide on basic pricing...one color, one side, two color, two sides, large imrprint, small imprint, etc... Set up an order/pricing form that covers the basics. Once you get that down....you can take the next step up to full color printed transfers. You can print these on an inkjet or laser printer and apply with heat press. They take a bit of trial & error to get the printing, heat & pressure settings just right....but are much faster than the vinyl. Good luck! Sue2 Share this post Link to post Share on other sites
jimwww 3 Posted June 4, 2011 Good advice - I plan to do the same thing. Share this post Link to post Share on other sites
