jammoresigns 0 Posted February 23, 2011 I have cleaned up and vectorized, using vectormagic, handdrawn type for a memorial stone to be sandblasted. am able to import it as eps and it looks great until I send it to cutter . the image then blacks out all the letter centers like in an O or a P and when I cut (ink paper) it does not recognize the O needs two cuts, it only cut the outside (all letters with a center) any ideas Thanks Jim Share this post Link to post Share on other sites
cutme 5 Posted February 23, 2011 I have cleaned up and vectorized, using vectormagic, handdrawn type for a memorial stone to be sandblasted. am able to import it as eps and it looks great until I send it to cutter . the image then blacks out all the letter centers like in an O or a P and when I cut (ink paper) it does not recognize the O needs two cuts, it only cut the outside (all letters with a center) any ideas Thanks Jim try select all > combine bb Share this post Link to post Share on other sites
jammoresigns 0 Posted February 24, 2011 That worked! Thanks Share this post Link to post Share on other sites
xJoey Dubsx 42 Posted February 24, 2011 Yeah, when you vectorize letters as shapes, the center is a different color (white, or whatever) so you need to make sure both are selected. Share this post Link to post Share on other sites
