VolleyChick 1 Posted November 9, 2010 Hello, I'm trying to send this graphic to someone as line art and I'm clueless. For the cutter I use Inkscape and it works fine, but when I sent an eps, it was rejected. My hard drive tanked and I can't find my Corel Draw CD to try to do it from there...any suggestions? Thanks! Di Note: I emailed back and told them I wasn't very good with graphics and asked what I needed to send, here is first response: You can trace the bitmap in Corel Draw which then turns into lineart, but then you have to adjust ever node to get the lines square and the curves looking good. It is hours of time in front of the screen, have fun and let me know. I emailed back and asked what do people with no graphic experience do and here is response: import image, select it, select bitmap and trace bitmap and detail logo, you can then play with the setting save it and once in corel select it, then break it apart, then the fun starts with adjusting each node of the letters. does that help? It is just me, or does this place not want to work with me? Share this post Link to post Share on other sites
Jay2703 704 Posted November 9, 2010 What are they going to use it for? Screen Print, Embroidery? Share this post Link to post Share on other sites
VolleyChick 1 Posted November 9, 2010 I'm guessing screen print - I asked but he didn't say. One of the girls on the team's husband is having a custom made volleyball net - on the tape of the net he wants her logo and mine so I'm trying to help out with the graphic. So far I'm not much help : p Share this post Link to post Share on other sites
Jay2703 704 Posted November 9, 2010 Di, I don't understand why they couldn't use an .eps file. I would try calling and talking to them in person. Find out what is needed. Jay Share this post Link to post Share on other sites
VolleyChick 1 Posted November 9, 2010 Hi Jay! This was his response when I sent a 2nd eps spaced differently than the first: That is the same art as the first file, they just change the file type. You can not take a image file and change the extension to make it a vector image. Or at least I do not know of software that will do it. Your letters will look like a saw blade (not straight lines or curves), if we were to print what you sent us. I had taken the png that's attached above and did a bitmap trace in Inkscape and saved as eps. I recently re-installed Inkscape so maybe my settings are off and it didn't come out well? I'm attaching what I sent if that helps. Di TKnet1.eps TKnet1.eps Share this post Link to post Share on other sites
bayotle 26 Posted November 9, 2010 I converted the file for you, see if sending the attached works.... TKVCnet.eps Share this post Link to post Share on other sites
VolleyChick 1 Posted November 9, 2010 Cool beans - thanks much I'll send it now! Di Share this post Link to post Share on other sites
bayotle 26 Posted November 9, 2010 Cool beans - thanks much I'll send it now! Di Ok, who stole the thumbs up icon? Dayum another customer! Share this post Link to post Share on other sites
VolleyChick 1 Posted November 9, 2010 YAY - thanks so much - it worked!!! Share this post Link to post Share on other sites
Jay2703 704 Posted November 9, 2010 Great to hear!! Share this post Link to post Share on other sites
bayotle 26 Posted November 10, 2010 < insert thumbs up icon here > Cool, glad it worked! Share this post Link to post Share on other sites
VolleyChick 1 Posted November 10, 2010 This is the never-ending post, sorry to keep asking for help! So the graphic format is fine but now he's asking for this: send the art again and change space between tk & vc to be 8.5". I can not adjust the art they sent, for whatever reason I do not know. that will make it 8.5 " apart repeated 9 times with the width of 32.5" and a start and end of 11.75" I made a new graphic (that hopefully meets the criteria) could you convert this file? Thanks!! Share this post Link to post Share on other sites
Jay2703 704 Posted November 10, 2010 Di, look at the difference between the initial file you created and the one Bayotle did for you: Share this post Link to post Share on other sites
VolleyChick 1 Posted November 10, 2010 Hi Jay - I see the difference I just can't convert files, or did I do something wrong with the new one? It's been a long day so I confuse easily at this point... Share this post Link to post Share on other sites
Jay2703 704 Posted November 10, 2010 What program did you usee to create your original file? It would be good if we can get you to where you can give them what they need. Share this post Link to post Share on other sites
VolleyChick 1 Posted November 10, 2010 I used GIMP and for the cutter I use Inkscape to "vector" stuff with no problems, so outside of this situation I'm good to go. Share this post Link to post Share on other sites
rodh2 16 Posted November 10, 2010 See if this will help you. tkvc.eps Share this post Link to post Share on other sites
Jay2703 704 Posted November 10, 2010 What he was most likely having issues with was all of the layers in your file. There are 7 layers that appear to be the same thing. http://screencast.com/t/g26q0wicoGM Jay Share this post Link to post Share on other sites
VolleyChick 1 Posted November 10, 2010 Thanks so much Rod - I'll send them this now! Jay, I didn't post the file I sent to him up here since it was messed up. I posted the .png that I used to make it, but I'll attach what I originally sent now and maybe that will show what I did wrong. TKnet.eps TKnet.eps Share this post Link to post Share on other sites
rodh2 16 Posted November 10, 2010 Thanks so much Rod - I'll send them this now! Jay, I didn't post the file I sent to him up here since it was messed up. I posted the .png that I used to make it, but I'll attach what I originally sent now and maybe that will show what I did wrong. Hope it works for you.Rod Share this post Link to post Share on other sites
VolleyChick 1 Posted November 10, 2010 Me too - totally appreciate all the help on here - you guys ROCK!!!!!!!!!!! Share this post Link to post Share on other sites
rodh2 16 Posted November 11, 2010 So did they except the art VolleyChick? Share this post Link to post Share on other sites
VolleyChick 1 Posted November 11, 2010 I haven't heard anything...I'm hoping no news is good news but I'll let you know when I hear. Share this post Link to post Share on other sites
rodh2 16 Posted November 11, 2010 I haven't heard anything...I'm hoping no news is good news but I'll let you know when I hear. Good luck!!! Share this post Link to post Share on other sites
VolleyChick 1 Posted January 8, 2011 Better late than never - just wanted to thank everyone who helped with this - hope you all had wonderful holidays!! Tara's husband bought a canvas bag and dyed it pink, sent it to me and I added my logo and some others to and sent back. She was totally thrilled - I got a text as soon as she opened it. Her FB caption on the attached pic was: Best Christmas Present in the Universe! Thanks again!! Di Share this post Link to post Share on other sites
