redfish 1 Posted September 24, 2010 I am cutting a delicate font, there is no bold so I put a thin outline on the font in illustrator. I have stroked the outline now I have multiple parhs, How do I save to juat one path so I can cut? Share this post Link to post Share on other sites
scarby 0 Posted September 26, 2010 If you are wanting to put an outline on your text. Select your text. Go to Object/Path/Offset Path. Once you have your desired thickness, you can ungroup and delete original text leaving you a thicker font. Keep in mind that this will take away all text edit. Hope this helps. Share this post Link to post Share on other sites
