Connor
Cant figure it out????
I cant figure out how to create a mulit colored image using CorelDraw X5 that will keep its color when i transfer it to SignCut so i can cut by color.  Anyone know how i can accomplish this? Thanks.
Make 2 same squares with different colors and shift their positions.
For X5 you need to download the beta version which is mentioned on the SC pro page at the bottom.
Send the file to X5 with the application launcher.
Colors at the rigth hand side are displayed.
Paco
Is this the first time you used SC?
Did it worked with X4 if you ever used it?
Paco
first time ive used corel draw but when i take multi colored eps files off of a disk i have that is all eps files they show up in SC color cut ready.
If you export with launcher one red color square does it show as red in SC?
If you create your file (two offset squares in different colors and export (not save or save as) as .ai (version 7 or lower) file and import it by OPEN file in SC how does that whows up?
Paco
I am out of options.
I will prepare as SC file for you to see what happens if you open that.
Paco
