cncartworks 0 Posted February 27, 2007 When I ask this you'll know how new I am to the process. How do I put weeding lines in my sign? I have Flexi 7 Share this post Link to post Share on other sites
thredz 1 Posted February 27, 2007 IN the advanced tab of the production manager there is a box to check for easy weeding and a box for weed border. Share this post Link to post Share on other sites
cncartworks 0 Posted February 27, 2007 I told you I was new........... Share this post Link to post Share on other sites
cncartworks 0 Posted February 28, 2007 Well that did the trick. Now all I ned to do is get the cutting depth good so everything weeds easy. Thanks Bill Share this post Link to post Share on other sites
thredz 1 Posted February 28, 2007 You're welcome.If you will set the knife offset at .25 to .32 it will help close up the smaller cuts for easier weeding. Share this post Link to post Share on other sites
cncartworks 0 Posted February 28, 2007 Thats in the setup properties in the prod manager, right? Share this post Link to post Share on other sites
thredz 1 Posted February 28, 2007 I don't have it up right now because I am using signcut,but I think it is in the production manager setup - job defaults - cutter options. If you had a copam cp-2500 you would set it on the cutter.I have mine set at .25 .It seems to do the job.But some have set theirs at around 32.Just take some time and run a couple of small cuts with the offset graduated from 25 to 32 and see which results suit your needs. Share this post Link to post Share on other sites
cncartworks 0 Posted February 28, 2007 The only place I could find it wasin the production manager. Under the setup properties , in the cutter. I checked the box that said Knief offset, and set it to .25. It wasn't checked so I guess there was no offset. Share this post Link to post Share on other sites
thredz 1 Posted February 28, 2007 Right.If you are using the refine cutter you have to deignate it in the program.I think the default setting in most drivers is set to off because everyone has different setups they use. Share this post Link to post Share on other sites
cncartworks 0 Posted February 28, 2007 Thanks again. I will be giving it a try in the AM. Share this post Link to post Share on other sites
