mattyb777 2 Posted August 27, 2010 does anyone have any instructions on replacing? thanks in advance, matt Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 27, 2010 Remove bottom of cutter, remove wires, remove screws on mb, reverse Share this post Link to post Share on other sites
mattyb777 2 Posted August 27, 2010 wow....really? thanks for all of your help Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 28, 2010 same thing for p-cut, refine, copam . . . .The Rolands are a lot harder though, and more expensive Share this post Link to post Share on other sites
mattyb777 2 Posted August 30, 2010 got the motherboard, put it in, everything works......EXCEPT.....now the vinyl isnt advancing after a cut. The carraige just stops and the vinyl doesnt advance....I have to advance it manually. I checked the settings in signblazer but they are the same as before. Any ideas what this could be? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 30, 2010 in the cutter set up under the cut menu, advance after cut has to be checked- the cutter can only take the instructions given by the software Share this post Link to post Share on other sites
mattyb777 2 Posted September 22, 2010 Weird....I have to change the advance job to 2" so the machine will advance it .25".... Also, once I installed the new motherboard, it seems WAY faster. I had to adjust the speed to 10cm/sec so it wouldnt go too fast....anyone know of a reason that would happen? Share this post Link to post Share on other sites
