stew
Registration marks in Elements
Does Element have a option for registration marks?,..was reading help manual for version 5, it states to go to copy - install registration marks?? there is no option for this?:thumbsup:
I do the same thing.  I draw a box with a circle in it, then copy and past it in the desired locations.  If I'm only doing two colors, I cut the box/circle with each color.  Then I weed out the circle on one color, and weed out the box on the other.  Works Great!
-Dan
Hi Guys,
here are two helpful hints ---
1. Select an object and then press the + key on the number keypad on the RHS of your keyboard.
This puts a duplicate exactly on top.
2. Use Color Select to select just the duplicate (RH click on color bar) and turn off Auto Select.
Now you can change the top selection to another color easily for registration marks.
Jerry from SignBlazer.
