rslack 0 Posted June 17, 2010 What kind of application paper holder does everybody use? I am using the one that came with my cutter and it does not work worth a flip or maybe I am not using it properly. I do appreciate all the help that I have received from everyone. Thanks Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 17, 2010 2 things - do you run the app tape under the front roller? second get a big squeegee and get rid of the holder! Share this post Link to post Share on other sites
megacab 1 Posted June 19, 2010 the big squegee is the best money on a tool that i have spent yet. Share this post Link to post Share on other sites
mopar691 281 Posted June 19, 2010 Got my Big Squeegee on monday, and all i can say is Wow, i wish i would of had this from the start. I got both the cut vinyl tool one and the laminate one cause i couldntmake up my mind, plus i would like to "waminate" (as my wife says) some of my large prints. Share this post Link to post Share on other sites
LEISUREBEACH 0 Posted June 19, 2010 Do you have pics as I would like to see what you purchased or maybe a link to where you purchased.Thanks Share this post Link to post Share on other sites
mopar691 281 Posted June 19, 2010 heres where i got mine http://www.signwarehouse.com/c-TT-BS.html Share this post Link to post Share on other sites
LEISUREBEACH 0 Posted June 21, 2010 OK here goes th dumb ? Do you use this for applying your application tape for vinyl jobs? If so could you explain why it works better then just the small squeegee's? Thanks for any help. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 21, 2010 used for applying the application tape or great for applying a graphic to coro or other sign substrate. using the Bs you get no wrinkles and is easier to apply the app tape Share this post Link to post Share on other sites
john! 1 Posted June 21, 2010 i use the laminator for the print mounting AND app tape. You should have just got 1, it does it all to be honest. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 22, 2010 i use the laminator for the print mounting AND app tape. You should have just got 1, it does it all to be honest. when I find a deal like I got on the 40" rotary paper cutter Share this post Link to post Share on other sites
mopar691 281 Posted June 22, 2010 well i got the big laminat tool and the small cut vinyl tool so that helped in my mind justify both a bit, lol. Share this post Link to post Share on other sites
