fracsuperstar421
font issue
haveing a prob in corel when i pick a font  i need it to be bigger so ytou can read it  fater  for the lack of better term not sure how i do this  any help thank you
If you trying to make the font bolder, you can, convert to curves, break curve apart, then stretch to meet you needs.
Or you can, convert to curves, then add a countour to widen the letters.
If you post an eps file of the image your working on I see if I can help you.
Select the font with the arrow in the toolbar.
Black blocks around the font will appear.
Put the cursor on the right hand top side and drag the font to a larger value.
Easy?
Or change the value in the yellow marked as showned int the attached picture.
Unlock and lock the lock beside it to to see what happens more.......
Paco
