wwpro 1 Posted May 2, 2010 Hi there FlexiSign-Pro 8.5 doesn't let me change my vinyl size. It sets itself to a maximum of 18.5 inches wide and I'm trying to set it to use a 24inch roll but shows a message asking for a number between 0 and 18.5 ?? Went thru setting several times but I can't find where to change it. Any help would be appreciated Thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 2, 2010 what cutter do you have listed in the Production manager for a set up? and when you have your cut/plot screen open what cutter is listed at the top? Share this post Link to post Share on other sites
wwpro 1 Posted May 2, 2010 PNC-1000 but it really is a MH871 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 2, 2010 why use PNC1000, when Us Cutter 871 is listed in Flexi as a set up option? I have 8.6 and it is there... Have you tried to set it up on that? The set up model determines what material width to use in Flexi. Such as mine is a 30" Graphtec, so it allows my width to go at 29.6" x1968 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 2, 2010 I also have 8.5 I don't see it listed, as US Cutter probably why your using Roland. Share this post Link to post Share on other sites
wwpro 1 Posted May 2, 2010 Exactly, no UsCutter driver, I was using 7.6 before and used the PCN-1000 driver with no problems. :- Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 3, 2010 see if setting it up on a Copam 36" model CP3050 (36" model )would work it's same driver. and will be wider in your Flexi. Share this post Link to post Share on other sites
wwpro 1 Posted May 3, 2010 let me try and I'll report back thanks Share this post Link to post Share on other sites
wwpro 1 Posted May 3, 2010 That worked just fine, hopefully won't bring any issues later one and stays like now thanks for taking the time to help me out Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 3, 2010 yes, but his user defined would not go higher than 18.5" because of the model entered on setup. Just like mine won't go past 29.6" because my model is 30" Graphtec. Can go lower/ but not higher,, Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 3, 2010 That worked just fine, hopefully won't bring any issues later one and stays like now thanks for taking the time to help me out your welcome, goodluck with it. Share this post Link to post Share on other sites
Toolman 1 Posted May 3, 2010 Take this link get the driver pack for Flexi. install per readme re start flexi. You can then pick which US Cutter you have and it will have sorrect media size. Hope this helps http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=44&nav=0,4 Share this post Link to post Share on other sites
wwpro 1 Posted May 3, 2010 Appreciate the link Toolman, but since the Copam driver is working fine I'd just keep it. I'm going to download yours anyway just in case Share this post Link to post Share on other sites
Toolman 1 Posted May 3, 2010 No Problem, I got it for my MH 721 works like a champ, Keeps the settings I kept losing them everytime I opened production manager. Now it has them every time I cut. Share this post Link to post Share on other sites
