kpsxtyone 0 Posted April 27, 2010 Hi All, I had the cutter for few months now and I am venturing the contour cut feature.. I am using Illy with singcut pro. this is what i did ( i did calibrate the pen before and after) -export to signcut to just plot the star. so it did plot the star with 4 reg marks. -moved the paper a bit - clicked on simple contour cut - calibrated 3 reg marks and clicked on cut The problem that i have is that its all off.. well its kinda shrunken in the middle. With the image below you can see the outer star and 4 reg marks.. those are the first plot that i did and the inner part is contour cut part. Any suggestions? Thanks, Ryan Share this post Link to post Share on other sites
