dgdcustoms 0 Posted April 15, 2010 I got my image imported and ready to cut. But when I cut the sticker the out line around it is way to thin. How can I make that thicker so it will weed out and stick? I tryed to import it into SB but when I do all I get is a solid back ground with no out line... Thanks Share this post Link to post Share on other sites
tinaski 11 Posted April 15, 2010 try click on image ctrl + shift + ) that is short key for outset -- of you can go to on eof the drop down from the top dont remember what one -- sometimes that doesnt work not sure but worth a try ------ can you post the image Share this post Link to post Share on other sites
slacker 0 Posted April 15, 2010 I don't have a cutter however, have you tried to change the width in the stroke style dialog box? Share this post Link to post Share on other sites
tinaski 11 Posted April 15, 2010 I don't have a cutter however, have you tried to change the width in the stroke style dialog box? i dont believe stroke style will not change the cutting area -- if you have a stroke of .1 inch it will cut in the middle if you have a stroke of 1 inch it will still cut in the middle stroke is just a single cut it isnt cutting one both sides of the stroke well thats how it is for me but my stuff is a little diffrent than most Share this post Link to post Share on other sites
dgdcustoms 0 Posted April 15, 2010 I cant seem to figure out how to post the dang thing... any pionters? Or I can email it to some one... Share this post Link to post Share on other sites
dgdcustoms 0 Posted April 15, 2010 I have been trying to get this up since I posted my problem Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 15, 2010 here are some inkscape manuals, maybe they can help you http://en.flossmanuals.net/Inkscape/ http://tavmjong.free.fr/INKSCAPE/MANUAL/html/index.php http://www.angelfire.com/mi/kevincharles/inkscape/index.html Share this post Link to post Share on other sites
tinaski 11 Posted April 15, 2010 advanced options - limited on file size and it has to be the right format pdf - eps - svg (i think you can load ) email it to me if you want Share this post Link to post Share on other sites
dgdcustoms 0 Posted April 15, 2010 here are some inkscape manuals, maybe they can help you http://en.flossmanuals.net/Inkscape/ http://tavmjong.free.fr/INKSCAPE/MANUAL/html/index.php http://www.angelfire.com/mi/kevincharles/inkscape/index.html Thanks!! I will read up on these. I just started using inkscape. But I figured out how to import and export,kinda. I was told that this happens becuase the file is to new for SB to read right?? Share this post Link to post Share on other sites
tinaski 11 Posted April 15, 2010 ok try this sorry it took so long to get back with ya what i did i couldnt do anything with the eps or pdf you gave me so i took the jpeg vectored it and copy paste it - so i had 2 vectors on the same page then del all the nodes of the letters of one and del all the vectors of the border of the other then pu them back together and clicked on the border High liight it - then clicked ctrl+shift+) to make it thicker if its not thick enough just do it some more again sorry it took so long thanks BajaBash_2010sticker.eps BajaBash_2010sticker.eps Share this post Link to post Share on other sites
