Southern Bred 0 Posted April 1, 2010 ok well im new to this and been using my cutter to cut letters and words. but when i tried to cut numbers it never completes the cut. it will start cutting fine then like die out and go crazy than drag the blade across the vinyl plz help Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 1, 2010 have you contacted Bridge about your problem? Here is their info and they also have a forum.. http://www.bridgecutters.com/ Share this post Link to post Share on other sites
Southern Bred 0 Posted April 1, 2010 no i havent and ok thank you im new to this my plotter is just for personal use but cant use when broke lol Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 1, 2010 sounds like a blade offset problem.. try changing it in .05 increments go plus if it goes worse, go minus. Every machine has to be fine turned, Share this post Link to post Share on other sites
Southern Bred 0 Posted April 1, 2010 and how might i do that ? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 1, 2010 you do not state what cutting software you are using... it is in your cutting software, If using Signblazer, it will be under the cutter setup. Share this post Link to post Share on other sites
