LOBO 0 Posted March 23, 2010 has anyone come across this problem before... the cutter is working fine.. but....... it's cutting some letters 2 to 3 times in the exact same place... example.. letter "O" will cut it once,, start over cut 2nd time.. start over,,, cut a third time.. ive switched fonts.. will also do it.. ok.. does not do it 100percent of the time.. but enough to say.. WTF!!!!..... any help is appreciated have LP24 toshiba tablet USB..Vista.. Share this post Link to post Share on other sites
MrMopar64 47 Posted March 24, 2010 Are you sure there isn't more than one layer... sometimes (and I don't know why) I've highlited my type to move it on the page and it leaves a copy behind which I'm thinking is another layer... new to this so I don't know where it comes from but I just delete it and cut without a problem MM64 Share this post Link to post Share on other sites
LOBO 0 Posted March 30, 2010 paco.. its signblazer its a circular pattern with letters all the way around.. the top half of the circle it cuts just fine but when its cutting the bottom half of the circle.. all letter it cuts 2-3 times each... ive tried with zero outline.. hairline.. still the same any ideas? Share this post Link to post Share on other sites
hockeygirl 30 Posted March 30, 2010 post your file, maybe one of us can see what's going on. Share this post Link to post Share on other sites
TSQUIRTZ 0 Posted March 30, 2010 Sounds like you have duplicate copies of your letters stack on to of each other. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 30, 2010 Sounds like you have duplicate copies of your letters stack on to of each other. ++1 Share this post Link to post Share on other sites
LOBO 0 Posted April 4, 2010 tquirts... you were right... but how does it come up with multiple layers. if its a single text layer when I export it to SB... Actually.. some of the letters had 3-4 layers on top of each other and others only 1.. WTF.. hmmm........ Share this post Link to post Share on other sites
LOBO 0 Posted April 4, 2010 how do i keep this from happening?.. it will be a pain in the Donkey... to have to go thru all work and check for multple images. Share this post Link to post Share on other sites
cohort 0 Posted April 5, 2010 The only time I had a problem with that so far is when I made an object (a star) and didn't covert it to a curve before exporting - perhaps this might be what's happening for you. Share this post Link to post Share on other sites
LOBO 0 Posted April 5, 2010 well,, i'm using corel X4 and when i export it always asks if i want to convert to curves.. so exported to curves to SB.. not all objects have a double image. Only some.. may just have to check all before cutting.. hmmm.. how can i check for multiple layers on SB? Besides selecting and moving one piece at a time. Share this post Link to post Share on other sites
cohort 0 Posted April 6, 2010 hmmm.. how can i check for multiple layers on SB? Besides selecting and moving one piece at a time. drag a selection box over a part you're concerned about and look at the status bar - it'll tell you how many objects are stacked. Share this post Link to post Share on other sites
LOBO 0 Posted April 7, 2010 simple enough.. thanks cohort. will do that Share this post Link to post Share on other sites
TruckDriver 0 Posted April 13, 2010 hmmm.. how can i check for multiple layers on SB? Besides selecting and moving one piece at a time. drag a selection box over a part you're concerned about and look at the status bar - it'll tell you how many objects are stacked. I learn something new every day here! Thanks! Share this post Link to post Share on other sites
cohort 0 Posted April 14, 2010 Make sure you start your selection drag from outside the bounding box of all objects, or you will drag one by mistake. Share this post Link to post Share on other sites
