edge 67 Posted March 5, 2010 SignCut Pro w/dongle has been cutting fine until yesterday. Perhaps I errored in asking my computer to multitask by copying a vector to a thumb drive for another computer while actively cutting with SignCut...I don't know. I do know now midway into a cut, the copam has a mind of it's own, first it cuts long lines across the project, then it parks the blade to the side and scrolls the vinyl until I react. Checked to insure the file I was launching from Corel wasn't corrupt. Next I reinstalled SignCut Pro. None of the projects I tried are large and none exceed the vinyl parameters. Several times when I interrupt the bad cut; SignCut Pro has locked on me. Guess I'll have to ponder this overnight. As an aside, both times I've installed SignCut Pro, I get a quick flash that McAfee has blocked a Trojan. It flashes to fast for me to get all the details..however I don't think it's nefarious..but rather something associated with SignCut. Any suggestions? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted March 5, 2010 turn off your anti-virus when installing. Share this post Link to post Share on other sites
edge 67 Posted March 6, 2010 I looked at the project in Corel giving me issues again and decided it may not be as flaw free as thought. Don't know if it's an open segment that I just don't see or whatever. Had the same project in SignBlazer, so that was a solution. Was gonna go with John's suggestion..then decided to look at my program files before hand. In spite of removing SignCut X2 thru the XP control panel previously, I found it's program file still there; just chocked full of stuff. Did another removal of it and SignCut Pro as I wondered about conflict between the two, then reinstalled Pro. McAfee apparently has only quarantined the suspect file during install. I suppose I should release the file, but Pro is back to cutting as it should with the exception of that one project...so I'm gonna leave things as they are for now. Thanks Share this post Link to post Share on other sites
