stewiegriffin 0 Posted December 13, 2009 So whats the proper way , when I save an image and just try to cut it in flexsign it says no cuttable object. I open it up in adobe illustrator and live trace it, but it distorts some lines on particular images. So is there any other way to go about this easier ? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 13, 2009 Most all images require some clean up after you vectorize them .. I use Illy CS2 and no problems, You cannot just import a raster JPEG, BITMAP image into Flexi, I am assuming you mean Flexistarter,,, The image has to be vectorized first. You can also use a FREE program like www.inkscape.org and vectorize images. Share this post Link to post Share on other sites
stewiegriffin 0 Posted December 13, 2009 I'm using FlexiSign-Pro , I have adobe photoshop cs2, and illustrator cs4 Share this post Link to post Share on other sites
YadirellT 0 Posted December 14, 2009 If your image is good enough to trace, you'll want to import it into Illustrator. Use Illustrator to vectorize your image. As Speedy said, you'll likely need to do a good amount of cleaning up before you get yourself a good clean cuttable object. Once you have this image vectorized to your satisfaction, import into Flexi and send it to the cutter. Share this post Link to post Share on other sites
mark-s 1,126 Posted December 29, 2009 You can vector within Flexi Pro. mark-s Share this post Link to post Share on other sites
MrMopar64 47 Posted January 29, 2010 What Mark-s said... Just click on the bitmap button pick rastarize when it's done click the bitmap button again and pick vectorize then select your image it will end up a vector MM64 Share this post Link to post Share on other sites
