anahm09 0 Posted December 11, 2009 I have followed all the steps to contour cut a decal, but after jogging the laser, I hit next and then click cut and it doesn't cut. Any ideas? This is my first attempt to contour cut. But I have followed the instructions. Thanks Share this post Link to post Share on other sites
anahm09 0 Posted December 12, 2009 I must be the first one to have this issue Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted December 12, 2009 what vinyl cutter? and what cutting software? Sorry, but you don't have enough info to help you. Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted December 12, 2009 I think you should go read the Laser point thread for help,, I don't use either product.. Make a post in the laser point thread if you can't get it. Possibly someone can help who has a laser pointer cutter http://forum.uscutter.com/index.php/board,42.0.html Share this post Link to post Share on other sites
cutme 5 Posted December 12, 2009 are you using the usb or serial connection? it doesn't seem to like to work on the usb connection where i have had no problems with it using the serial connection. bb Share this post Link to post Share on other sites
anahm09 0 Posted December 13, 2009 I am using a usb, which was a concern, but I have no problems when cutting even the most difficult vinyls. It is just when I click cut on the cut a print, it doesn't cut. Thanks for the help. Share this post Link to post Share on other sites
anahm09 0 Posted December 14, 2009 I am using USB, but it has no problem cutting anything else. Only when contour cutting. I don't have a computer with a serial 9pin. Is there anything else I can try to eliminate before I go buy a computer? Share this post Link to post Share on other sites
YadirellT 0 Posted December 14, 2009 Just curious, I apologize if you mentioned this and I missed it. But when you say it doesn't cut, is there no reaction from the cutter at all? Or do you get movement, but no proper cut? If you can kind of explain the process of the problem that would be great. It could be anything at this point from the USB connection, to the Driver, to just the setting on your cutting software. If it's doing other cuts, I would say configuration, but would need more info. Share this post Link to post Share on other sites
anahm09 0 Posted December 14, 2009 I can cut normally. But when attepmting to contour cut, I make the print it, make the outline, cut a print, jog, click cut. When I do so, I see it pop up for less than half a second, ("Cuting a Print") or somthing of that nature and at the bottom of the screen I see it load extreamly fast, but the cutter does not respond. It doesn't move the vinyl, the blade holder doesn't move, and the screen still says online. Thanks for the help. I would like to at least get some backing information before I build a computer only to find out that it was a different issue. I am not even sure having this cutter will be able to advance to anything other than cutting for friends and family. Share this post Link to post Share on other sites
anahm09 0 Posted December 16, 2009 Okay so I am officially frustrated. I just went out and built a computer specifically for this vinyl cutter, got the only motherboard they had that had serial 9 pin on it. Came home built it, connected the cutter and still no contour cut. Now that the battle between usb and serial is over with and I am out of $700 can someone please tell me what they think might be the issue. Again, I can cut normally, but when trying to contour cut, I can jog the laser left and right, but when I click cut, for a split second it says Cut a print... but the blade holder nor the vinyl ever move. I must have done something wrong in the screens leading up to the cut a print screen, I have tried deleting everything except the outline, I have tried everything I can think of with no luck Please help me. Share this post Link to post Share on other sites
YadirellT 0 Posted December 17, 2009 Anahm, please go to Support.Uscutter.com and submit a ticket, this should be something we can assist you with. Share this post Link to post Share on other sites
