paulzeee 1 Posted November 12, 2009 I drew this graphic and cut it out with SignCut but it cut along the exact line in the drawing. I was expecting it to cut around the line instead of on it. Is this part of the software not being setup correctly or is it the drawing? Thanks (dont mind the text, the image is from a computer that doesnt have the font i originally used) Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 13, 2009 it is the way you have the drawing,, it is supposed to cut on the lines. vector is the outline, You do not have a wide enough path/stroke,, if you expect it to be an outline drawing, you need to make all of the strokes/lines wider. then each line/path will have an outside and an inside to it. Share this post Link to post Share on other sites
Guest Posted November 13, 2009 it is the way you have the drawing,, it is supposed to cut on the lines. vector is the outline, You do not have a wide enough path/stroke,, if you expect it to be an outline drawing, you need to make all of the strokes/lines wider. then each line/path will have an outside and an inside to it. ;D Great advice. This is exactly what is needed. Share this post Link to post Share on other sites
