keleland 0 Posted November 7, 2007 Below the sheep's feet part of the botton line ("the ground") is cut out. Is there a way to repair that? Share this post Link to post Share on other sites
tservice 3 Posted November 7, 2007 Can you repost in a different format .eps or .svg or .jpg. Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 See if this did the trick. There was also alot of unnessecarry cut lines in the art I got rid of them too and welded it all together. Share this post Link to post Share on other sites
keleland 0 Posted November 7, 2007 FAB!!!! Now want to teach me the ways oh wise one??? Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 I'm not too good at explaining in a message. I basically filled the missing area in with a black box, selected all then opened the pathfinder window and clicked on merge to get rid of all the lines that don't need to be cut. Share this post Link to post Share on other sites
tservice 3 Posted November 7, 2007 What did you import the pdf into? Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 I opened it directly into illustrator CS Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 Sometimes if you have problems opening files in illustrator you can open a new document and PLACE the file on to the new document. Share this post Link to post Share on other sites
tservice 3 Posted November 7, 2007 I can't afford cs. I have ai 10. can i import a pdf into ai 10? Share this post Link to post Share on other sites
keleland 0 Posted November 7, 2007 How do I get it so that the horses legs blend into "the ground" as one piece? 3 Kings.eps 3 Kinds.ai 3 Kinds.eps 3 Kings.eps 3 Kinds.ai 3 Kinds.eps Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 I think I got what you need. There were clipping masks and a couple other things in there that made it a little more difficult. More steps than I can type. I got rid of the gradient. I hope you didn't need it. Let me know if it works. 3kings.eps 3kings.eps Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 I belive these are CS2 or greater. I had to place them on a new page. usually illustrator and .pdf go along good with each other. Share this post Link to post Share on other sites
keleland 0 Posted November 7, 2007 That's awesome!!! Thanks so much! I have so much to learn! Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 Great! Let me know if you have other problems. I've been using Illustrator for many years and have a pretty good handle of it Share this post Link to post Share on other sites
