williamssignco 0 Posted October 31, 2009 What is the best symbol to use as a reg mark? I do not like the on Flexi has built in. If you use something special will you share it? Thanks Share this post Link to post Share on other sites
James605 7 Posted October 31, 2009 a star or a diamond is what i use Share this post Link to post Share on other sites
Guest debogus Posted October 31, 2009 But wouldnt you have to make one for each color then stack them or is there a way to add to the registration mark libray? or maybe just substitute whats there ? Share this post Link to post Share on other sites
williamssignco 0 Posted October 31, 2009 But wouldn't you have to make one for each color then stack them or is there a way to add to the registration mark libray? or maybe just substitute whats there ? I am not sure I understand your question. But I will try and answer it anyway. Yes you need reg mark to line up the different colors. I do not like the reg mark in the software that I use, it is hard to weed. I have been using a Arial Capital Letter T as a reg mark right now. I may try the star or diamond to see if it is better. Thanks!! Share this post Link to post Share on other sites
grumpybadger 0 Posted October 31, 2009 I tend to use a diamond too. TBH as long as it is the same symbol on all layers/colours I don't suppose it really matters. Share this post Link to post Share on other sites
Guest debogus Posted October 31, 2009 That answered it . So use whatever symbol instead of the registration marks ,make one for every color. This is a good idea, glad someone brought it up Share this post Link to post Share on other sites
cpwall 0 Posted October 31, 2009 That answered it . So use whatever symbol instead of the registration marks ,make one for every color. This is a good idea, glad someone brought it up make one that doesn't match any color, then cut it with each color, that way you know its in the same place every time Share this post Link to post Share on other sites
Guest debogus Posted November 1, 2009 Not sure how on flexi cloned VE But from what I found works for my setup is say for three different colors use three different colored whatever shape then stack them ,then it will cut the "markers" along with each matching color . If I used a 4th color instead, it wouldn't work like a registration and would act like just another color layer. It only cuts all or one color. Something about the registration cross hair thing that it will cut that on every color with no extra steps Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 1, 2009 In flexi I just make my stars for registration marks and copy them, then paste over option as I paste over I change the color to one of the colors I am using. also changed the default color selection in flexi to the Oracal colors - makes it easier when designing and cutting! Share this post Link to post Share on other sites
sarconastic 29 Posted November 2, 2009 I don't understand why no one likes the flexi stock Reg Marks, they're great. Yeah you have to be careful when you weed them but if your doing multiple color they're prefect. You have 4 little triangles that make up the diamond. you remove a different triangle for each color. It may be that you ere not making your Reg marks big enough. I don't use the automatic registration marks in the Cut screen. I use the ones located in the Shape tool menu, then place them where I want a resize them up to about 5/8" Kevin Share this post Link to post Share on other sites
Guest debogus Posted November 6, 2009 5/8" ? duh, that was kind of obvious now that I think about it , they probably do work bigger Share this post Link to post Share on other sites
