dill 0 Posted November 3, 2007 Does Signblazer support tif. Files I was trying to import a graphic last night fron art explosion and wasn't having any luck. The graphic was a vector in the tif. formar. Thanks Share this post Link to post Share on other sites
tservice 3 Posted November 4, 2007 .tif is supported in sb. Can you see the file but not import? Share this post Link to post Share on other sites
dill 0 Posted November 4, 2007 When I attempted to Import, I got a bunch of blank squares on the screen as if it where trying to build an album. Share this post Link to post Share on other sites
tservice 3 Posted November 4, 2007 can you post the file? I will see if I can import it. Maybe just a bad file. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted November 4, 2007 When I attempted to Import, I got a bunch of blank squares on the screen as if it where trying to build an album. That's what you are seeing...the default signblazer folder.If there isn't anything in it,you won't see anything. You need to search for the image you want to import. In the upper right corner, double click on your C: drive,then double click on the folder that it is in. All importable images and files should show up. Share this post Link to post Share on other sites
dill 0 Posted November 4, 2007 Thanks, I will try that this afternoon. Share this post Link to post Share on other sites
