han7681 0 Posted October 27, 2009 HI IM CUTTING A VINYL STICKER LIKE THE PHOTO, THE EDGE IS NOT SMOOTH, IT LIKES LIKE A GEAR. HOW CAN I SET THE CUTTER? Share this post Link to post Share on other sites
Booper 2 Posted October 27, 2009 what type of cutter? What software? post up the vector file so we can look at it, etc etc....... Share this post Link to post Share on other sites
han7681 0 Posted October 27, 2009 im using us fine cutter and sign cut and art cut. both soft ware are same. looks like the photo. head.ai head.ai Share this post Link to post Share on other sites
prestonservco 26 Posted October 27, 2009 Uh oh. Check out this thread. I hope it's not the same problem. http://forum.uscutter.com/index.php/topic,22822.225.html Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted October 27, 2009 Thats about the third one to have that problem Share this post Link to post Share on other sites
Booper 2 Posted October 27, 2009 I just looked at your file hoping you had too many construction points but you dont, its smooth. You have a cutter issue. I'll cut it and take a pic of it for you hang on. Is the photo you took of the right hand side of what looks like the brim of a hat??? Share this post Link to post Share on other sites
Booper 2 Posted October 27, 2009 I just cut it, I did it at the size you posted, like 4 inches tall. Ben Share this post Link to post Share on other sites
han7681 0 Posted October 27, 2009 dear ben thanks for that!! if the file is not a problems, what is the problem with the cutter? i thought it might be too many construction point. i just bought the cutter a week ago. everything is new.. that was my first cutting very disappointed with the first cutting,,, Share this post Link to post Share on other sites
Booper 2 Posted October 27, 2009 Well if thats the first thing you've cut I would say you need to spend some time getting to learn the pressure, speed, and blade offsets and height of it. Spend a good couple hours and a few feet of vinyl and do lots of test cuts at different settings to see if they make any difference, worse or otherwise. If after all that your still having the exact same problem then it might be something wrong with the machine, but I think you should be able to get it dialed in. There's a TONNE of good info in the "Instructional Contributions" section, do some reading in there and you'll get alot of info on how to get it running smoother. Ben Share this post Link to post Share on other sites
gadget1961 5 Posted October 29, 2009 i was wondering if any one has settings on pressure for any machine at different vinyls , such as glitter and the more expensive to the cheaper types just curious thanks Share this post Link to post Share on other sites
