cox signs 0 Posted October 3, 2009 how do you align and center text in sb? i tried the align at the top tool bar doe not do anything could someone give a step by step how too ? thanks alot Share this post Link to post Share on other sites
Buggie Pilot 4 Posted October 4, 2009 I begin by making centered Guide Lines in my workspace. Do this by Right Clicking anywhere on the ruler at the top or side of your workspace. Then where it says add guides select Centre Workspace then OK After you type your text Select it. Line the center handle up with the center guide line and you should be all set. Sometime the Snap to Guide option in the lower right of your screen will do this automatically or it can cause the exact opposite of what you want to do Share this post Link to post Share on other sites
Jay2703 704 Posted October 4, 2009 how do you align and center text in sb? i tried the align at the top tool bar doe not do anything could someone give a step by step how too ? thanks alot If you are just trying to align two seperate peices of text, select them both then select Align. Set Aign to Selected, Vertical to none and Horizontal to Center. It will align the selected text center only in horizontal direction. If it is multiple lines it cannot be one peice of text. You align text like that in the text function with justification. Jay Share this post Link to post Share on other sites
