Maidstone 0 Posted September 23, 2009 Hi, I am making up my artwork in Coreldraw, making the outline into hairline and fill none, them exporting as eps vector. I open up Sign Blazer and input using full ps input. It cuts out great except there is two cuts around a letter leaving a hair width of material that comes away making it not easy to clear away. Is this normal? If there is a problem which program would it be? Thanks for any input. from David in UK Share this post Link to post Share on other sites
bamafan2277 50 Posted September 23, 2009 Can you post a copy of the file for us to examine closer? It could be that it has extra nodes causing it to do that. I had that problem when I first started vectorizing and found out my problem and started editing the nodes to make sure it didnt do it again. Share this post Link to post Share on other sites
Maidstone 0 Posted September 23, 2009 Oops I think my solution is in my question, when I admit I set the outline to hairline, reading other posts I realise I should set, outline to none. I will try that next, thanks. Share this post Link to post Share on other sites
