Creakhead 0 Posted July 28, 2009 With my pcut when I go into the the off-line mode and go to the test menu, and run a test. The cutter just starts cutting all sorts of dashes of different lengths. I remember it used to just cut a rectangle. Any ideas how I get it back to cutting the rectangle? Thanks Share this post Link to post Share on other sites
Guest sciondrgn Posted July 28, 2009 What test number is it set on? If I remember right playing with the test numbers did different things.. Take it back to 1 if its not set on it and try it Share this post Link to post Share on other sites
Creakhead 0 Posted July 28, 2009 It was set on Test 01, if i try any other number the print head just moves off to the left till it hits the kill switch. Share this post Link to post Share on other sites
Jay2703 704 Posted July 28, 2009 On mine when I take it off line and press pause twice it will cut a small test rectangle. Share this post Link to post Share on other sites
Creakhead 0 Posted July 28, 2009 Thanks! That did it, I guess its been awhile since i used my cutter. Share this post Link to post Share on other sites
jmonica 0 Posted August 13, 2009 On my PCUT (CT630) I was able to hit the pause button and a few other combinations of buttons [while it was offline[ and it started printing out this really cool demo that had a creation logo and all kinds of other shapes and letters and designs. I didn't want to waste the vinyl for the whole thing, but it seems like it would have printed a sheet about 4-5 ft long. My cutter is a 24" and the designs filled the width of it. Share this post Link to post Share on other sites
CRD 9 Posted August 14, 2009 Creation Pcut cutters come with two test files build in: 1] Hit pause key in offline state and it cuts a small square 20 x10 mm to test cut depth and weeding. Perform this test at several places on the vinyl width! 2] Other test is a large multiple lines and circle test. If you like to test it use the pen and 24"width paper. Paco Share this post Link to post Share on other sites
Derek Luhanga 0 Posted July 5, 2021 When i hit the pause button to test cut mine says 'insert U-disk'. Im new to this. Anyone help? Share this post Link to post Share on other sites
slice&dice 2,408 Posted July 5, 2021 Derek, good morning. OK<<<< so what happened after you inserted that U-disk? Share this post Link to post Share on other sites
Derek Luhanga 0 Posted July 5, 2021 I have no idea about the U-Disk. Thought its an error Share this post Link to post Share on other sites
