stickyicky612 0 Posted July 28, 2009 OK I POST SOMETHING BOUT MY MH 721 BUT NO REPLY ANYWAYS MY COMPUTER CANT READ THE USB I USE IT LIKE 2 WEEKSAGO EVERYTHING WAS FINE AND NOW I TRY EVERYTHING EVEN WHEN I PLUG IT IN AND PLUG IT OUT AND IN AGAIN, STILL DOESN'T RESPOND OR DETECT HAS ANYONE HAD THIS PROBLEM BEFORE? HAS ANYONE PUT A NEW US Cutter MH Mainboard Assembly - Square USB Port IN BEFORE? ANY HELP WILL BE NICE OR ILL JUST THROW THIS PIECES OF SHIT AWAY SORRY I JUST BEEN AT THIS FOR WEEKS, I HAVE TRY IT ON MY LAPTOP WITH VISTA TRY OVER 6 USB WIRE, DON'T KNOW WHAT TO DO NOW, AND TIME IS MONEY. ???HELP Share this post Link to post Share on other sites
BannerJohn 1,324 Posted July 28, 2009 have you tried to call tech support at US Cutter or submitted a support ticket? That would be your best option. I'm not sure anyone there reads the forums anymore. http://support.uscutter.com or to call in 1-888-298-8143 (use option 2 for support) Share this post Link to post Share on other sites
TaterNuts 3 Posted July 29, 2009 have you checked your device manager to see if it is detecting it there? any red x's or yellow exclamation points? Share this post Link to post Share on other sites
nbeaton 1 Posted July 29, 2009 I had that problem and I had to reinstall my drivers for my usb ports from the SBE disc. Share this post Link to post Share on other sites
bigjimt 1 Posted July 29, 2009 ry John I read them alot............but not all the time..........But your rignt call Ken Share this post Link to post Share on other sites
stickyicky612 0 Posted July 30, 2009 thanks for the reply have you checked your device manager to see if it is detecting it there? any red x's or yellow exclamation points? theres no red x's or yellow exclamation point it doesnt even pop up I had that problem and I had to reinstall my drivers for my usb ports from the SBE disc. i reinstall my driver and everything nothing works have you tried to call tech support at US Cutter or submitted a support ticket? That would be your best option. I'm not sure anyone there reads the forums anymore. http://support.uscutter.com or to call in 1-888-298-8143 (use option 2 for support) i just submitted a ticket they said my usb port must of got shock and i might need a new i/o board , but now i just bought a serial to usb connector to see if that would work. ill keep yall updated maybe this would help anyone else later on thanks Share this post Link to post Share on other sites
stickyicky612 0 Posted July 30, 2009 i bought a usb to serial converter set the setting that need to be set, Bite Per Second -9600,Data Bits-8, Parity-None,Stop Bits-1,Flow Control-Hardware, those are the setting, is the computer suppose to recognize the cutter ? cause it recognize the usb to serial converter. When i change the flow control to None it sends but cutter doesn't response any suggestion thanks Share this post Link to post Share on other sites
stickyicky612 0 Posted July 31, 2009 Yahoooo. i got it to work all you need to do was hook up the tan serial wire that came with the cutter in to the usb to serial converter ,as i just hook the converter in to the cutter with out the tan serial wire that came with the cutter, haha pretty funnyas i bought a "null modem adapter" that a us cutter support rep ask me to do but dont really need so but thanks anyways, hopefully this can help someone as i made a dumb mistake. Share this post Link to post Share on other sites
Brandon_Davis 1 Posted August 1, 2009 Good job... The cable and the adapter both serve the same purpose! Share this post Link to post Share on other sites
