fishintrippz 0 Posted October 7, 2007 Hello, OK I sent the file to the cutter and it showed how it would cut - as seen in the first attachement - but it actually cut it in the direction of the second. Any ideas? cut.doc cut.doc Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 8, 2007 In the first attachment,you have 'rotate across vinyl' checked. Is this how it was when you cut? Share this post Link to post Share on other sites
fishintrippz 0 Posted October 8, 2007 Yes, but shouldn't it cut the way it looks? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 8, 2007 yes,it should cut the way it looks in the one that you have that checked. Can't think why it didn't. Share this post Link to post Share on other sites
fishintrippz 0 Posted October 8, 2007 Here is another cut I just did. It's still cutting backwards so I just had it look like that changed my vinyl size to 24, so it would cut it and then it cut long ways like I wanted it. Is this a quirk in the trial program? I don't want to have to be thinking about this everytime I send it to the cutter. halloweencut.doc halloweencut.doc Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 8, 2007 I've been playing with it and can't think why it isn't cutting as it is supposed to. Maybe Bruce cxan help. One thing I noticed,that I didn't before..am I seeing things,or are the markers in the rulers wrong? I am counting 8 markers at the 10 inch mark,etc. Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted October 9, 2007 What you should end up with for the halloweencut is: if you look at the cutter from the front, you should have "Happy Halloween" upside down across the width of the vinyl. Is this what you get? If not, what cutter and driver are you using? Share this post Link to post Share on other sites
fishintrippz 0 Posted October 9, 2007 Nope it took it Vertical went all the way up the paper. I am using aJSI cut 24 don't know what driver? Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted October 10, 2007 Which version of SignBlazer Elements are you using? The USCutter version of SignBlazer Elements doesn't include a driver for the JSI cut 24. Share this post Link to post Share on other sites
fishintrippz 0 Posted October 10, 2007 6.0.16 is the release number Bruce. Is there something else, I can try or buy? Thanks Kendra Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted October 10, 2007 What does SignBlazer have in the title bar? It could be: SignBlazer Elements SignBlazer Elements for USCutter SignBlazer Elements for ...... Also goto the cut screen and click on the "setup" button and see what cutter is selected. Share this post Link to post Share on other sites
fishintrippz 0 Posted October 10, 2007 Hi there, under cutter it says JSI24, I can't find anything else about it. Share this post Link to post Share on other sites
