cashman 0 Posted July 7, 2009 when my pcut cuts from left to right it leaves chattered lines. It is like it is skipping. Not sure how to explain it but when i weed the vinyl it feel like dashes in the vinyl and the line is a little wavy. when it cuts up and down or right to left it seems perfect. any help would be perfect. thanks Share this post Link to post Share on other sites
Buggie Pilot 4 Posted July 8, 2009 I would try. Clean your blade , Check depth, Share this post Link to post Share on other sites
Guest sciondrgn Posted July 8, 2009 May need to had a little more down force pressure as well.. Share this post Link to post Share on other sites
kenimes 42 Posted July 8, 2009 Set the pressure on the cutter to at least 120 or higher, and make sure just the very tip of the blade is exposed. It should hardly be sticking out at all. Share this post Link to post Share on other sites
MGOMEZ 0 Posted July 8, 2009 i have the same problem and have been adjusting the blade and adding pressure and it is helping with the problem. it only dose it with certain types of vinyl. lately i have had to mess with it more, i think i am close to 150 on the pressure. Share this post Link to post Share on other sites
bmastiff 0 Posted July 26, 2009 mine does the same thing I adjust and it seams fine for awhile then it starts again I'm wondering if i need a new blade holder, thinking maybe a bearing has gone bad it only does it going left to right Share this post Link to post Share on other sites
Guest sciondrgn Posted July 27, 2009 mine does the same thing I adjust and it seams fine for awhile then it starts again I'm wondering if i need a new blade holder, thinking maybe a bearing has gone bad it only does it going left to right Mine would do the same.. Just have to find the sweet spot with blade length and pressure Share this post Link to post Share on other sites
sarconastic 29 Posted July 28, 2009 My bearing holder is crappy, and I get this occasionally. I need to get a new one ordered just haven't found the time. It's still under warranty, but I can't be down right now. It seems to make a difference on angle and direction with mine. Kevin Share this post Link to post Share on other sites
