kctrader 10 Posted July 3, 2009 Got my first roll of Siser Easyweed today amd I'm ready to give this a try....but the teflon sheet didn't arrive. I really don't want to wait until next week to start experimenting with the press. Does anybody know if a non stick oven liner will work in a pinch? Target has one that is made of silicone, the other doesn't say, but looks a lot like a teflon sheet, only a bit thicker. Both are rated to 550 degrees. Thanks. Share this post Link to post Share on other sites
Renegade 2 Posted July 3, 2009 Just get you a package of silicone parchment paper in the baking supplies. Share this post Link to post Share on other sites
kctrader 10 Posted July 3, 2009 I'll go look for them. Thanks. Share this post Link to post Share on other sites
MikeMan 0 Posted July 3, 2009 You can press without the teflon sheet in a pinch with EZ Weed, just make sure you don't put the vinyl in the press upside down... Share this post Link to post Share on other sites
midwaste 4 Posted July 4, 2009 I just took two pieces of backer paper and stuck them together. I havent had any problems with it. Share this post Link to post Share on other sites
edge 67 Posted July 5, 2009 Does anybody know if a non stick oven liner will work in a pinch? Target has one that is made of silicone, the other doesn't say, but looks a lot like a teflon sheet, only a bit thicker. Both are rated to 550 degrees. Thanks. If you are referring to the blue teflon silicone sheets, they act like a heat sink and do not allow enough heat to transfer thru. Share this post Link to post Share on other sites
bayshorecreations 30 Posted July 6, 2009 Put a piece of 20lb bond paper between the vinyl and the platen. That's what I use, works like a charm. Share this post Link to post Share on other sites
