Nightwolf 0 Posted June 21, 2009 Hi, just to be honest, i am a newb. I bought a Procut CR630 at a yard sale. Guy said it was replaced in his shop with a better model. Issue is it was just the cutter a blade and a power and USB cable, no software ECT, I found a driver of some sort that makes the PC read it as a Serial so i have it on comport 2 with the machine set to a 9600 baud rate. with hardware flow control. HOWEVER, the plotter/cutter is not being picked up in windows. I still need Physical drivers. PLEASE HELP. {BTW i am a cutter/plotter noob, not a PC noob } Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 21, 2009 welcome, maybe you can find something in here... I do not have that type of cutter... http://support.uscutter.com/index.php?_m=downloads&_a=view you can also dowload the free Sign Blazers Elements to use for your signware. Share this post Link to post Share on other sites
Nightwolf 0 Posted June 21, 2009 So now i got that setup that is nothing more than a USB serial adapter will the sign blazer have the driver like Flexi does? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 22, 2009 I do not use Sign Blazer, So I do not know what drivers they use. Share this post Link to post Share on other sites
Nightwolf 0 Posted June 22, 2009 Ok now this it really annoying i can use the cutter but it cuts the paper on one side Share this post Link to post Share on other sites
Brandon_Davis 1 Posted June 27, 2009 Nightwolf you have to adjust some settings thats all... Probably a small amount of machine maitenance too.. Which side is it cutting all the way through on? Are you sure it's really just on one side? If you look at the cutter's lcd display and can figure out what level of force the cutter is set it might be a big indicator of why it is going all the way through... Alternatively there are some other settings we can adjust not to mention if your blade is properly seated. Report back on the force to start... I am glad we could get you some help here on the USCutter.com forum. Share this post Link to post Share on other sites
