kevin3vd1 0 Posted June 17, 2009 Width for Applications tape that works best for a 24" cutter. Is 6" tape and 12" OK 2 Start with? I plan to so decals for window, and larger signs. I'd use the 12" for the larger signs. Any input? Thanks Share this post Link to post Share on other sites
midwaste 4 Posted June 17, 2009 I'd get a roll of 24" paper for the signs, just so you dont have to overlap all the time. It's cheap enough to do that. I've neved used anything but 24" and 12" clear tape for decals. I may have wasted a bit of the 12", but it was worth it. Overlapping is not worth the hassle unless you are in a bind, apptape is not that expensive.. Share this post Link to post Share on other sites
swaneejuggalo 0 Posted June 17, 2009 I use 10 and 12 but i mainly do bulk 8" to 12" decals.. Share this post Link to post Share on other sites
Tempted Graphics 0 Posted June 17, 2009 4, 8 and 24 inch and you will be good to go Share this post Link to post Share on other sites
Benr98 40 Posted June 17, 2009 I use mainly 6", 8", 10" on average. But have had 12" when I need it. It really does depend on what you are going to be using it for. Share this post Link to post Share on other sites
tlzimmerman 11 Posted June 17, 2009 I try to get one inch longer, so like 13" and 7 or 8 " most of the time, helps when you are doing that 12" decal to have some overlap. Share this post Link to post Share on other sites
Guest round2racing Posted June 17, 2009 I have 6 and 12. It works out perfectly for me. I don't mind overlapping, because I usually end up using a piece of 12 and a piece of 6. Works for me. You have to try out different sizes and decide what's right for you. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 17, 2009 I keep 30" 24" 18" 15" 12" 6" of conform R-Tape 7050RLA paper tape, as I do quite a few different sized vehicle graphics,, I purchase a 48" log and have it slit to my measurements,, 24" is my most used tape though,,,as most vehicle graphics run 20-22" wide by 90"-120" length, Share this post Link to post Share on other sites
Jay2703 704 Posted June 17, 2009 I use 6", and 14" mostly. I have a roll of 24" for 24" wide vinyl. Share this post Link to post Share on other sites
Buggie Pilot 4 Posted June 17, 2009 I use 2",4",6", 8", 16" R-Tape.....mostly use 6" Share this post Link to post Share on other sites
kevin3vd1 0 Posted June 17, 2009 Thanks for the input. Really appreciate it. Kevin Share this post Link to post Share on other sites
Guest round2racing Posted June 18, 2009 Kevin, You'll have to get a few sizes and figure out what combination works for you. What size you buy is going to depend mainly on what you are cutting. If you are doing decals over 12" or so, you may want the larger sizes. Whatever your "main" selling item is going to be should dictate what sizes of app tape you are going to keep on hand... Share this post Link to post Share on other sites
