duke 12 Posted June 16, 2009 I have recently reinstalled s/b, now i can't import any images so i can cut them. I have tried all formats, but no go. Can anyone tell me what the problem is? Regards Duke Share this post Link to post Share on other sites
Jay2703 704 Posted June 17, 2009 You have been able to import in the past? I would try to re-install again. Share this post Link to post Share on other sites
duke 12 Posted June 17, 2009 Thanks Jay I will try that. Share this post Link to post Share on other sites
Jay2703 704 Posted June 17, 2009 What does it do when you try to import? Nothing or Crash? Share this post Link to post Share on other sites
duke 12 Posted June 17, 2009 Hi jay. nothing is showing up on the s/b tiles when I hit import when I select my design :'( Share this post Link to post Share on other sites
Jay2703 704 Posted June 17, 2009 Are you using the Full Postscript Interpreter option option or the Postscript Scanner. I will usually start with Full and if that does not work I sill use the other. Sometimes it is the .eps file. If they are too new of a version SB will not handle them. Where did you get the .eps from? Share this post Link to post Share on other sites
duke 12 Posted June 17, 2009 Hi Jay, I can't import anything. Share this post Link to post Share on other sites
Jay2703 704 Posted June 17, 2009 I would go with the re-install then. Share this post Link to post Share on other sites
woodruff 0 Posted June 17, 2009 I have this same problem with my sign blazer software, its only a few months old, but ive never been able to import an image, it simply doesnt work. Share this post Link to post Share on other sites
Brandon_Davis 1 Posted June 17, 2009 This is a common problem... If a reinstall does not work then there is an alternative procedure, did you have any luck with the re-install? Share this post Link to post Share on other sites
duke 12 Posted June 17, 2009 Reinstall didn't work. :'( Share this post Link to post Share on other sites
sspvinyl 6 Posted June 19, 2009 having this same problem on certain items. or if it works the image looks screwy Share this post Link to post Share on other sites
Guest round2racing Posted June 19, 2009 Same here. Sometimes i go through all the steps and still get nothing into SBE. Brandon? Do you have some magic trick up your sleeve? Share this post Link to post Share on other sites
ViciousVinyl 0 Posted July 1, 2009 I have had some issues importing files. Generally I just copy and paste. When you first do it nothing will show up until you click in the artbox and "jiggle" it a bit. This is the "method" that I've been using since I installed SB. Hope this helps! Share this post Link to post Share on other sites
cutme 5 Posted July 1, 2009 do you have other software you can open the files with? post up a file you cannot open, so others can try. i use illy to convert files that won't open in sbe. bb Share this post Link to post Share on other sites
duke 12 Posted July 1, 2009 This is a common problem... If a reinstall does not work then there is an alternative procedure, did you have any luck with the re-install? Hi Brandon, what is the alternative? Regards Duke Share this post Link to post Share on other sites
