Xtremethrottle 0 Posted May 5, 2009 For years i have been using a ZUND plotter machine with a program called icut. Its a very expensive software and i just bought i small copam so i can travel around with it and i cant use my icut software and im forced to use this one. i cant even get any of my files to open. All my file are .AI format which should be fine but i keep getting an error even before i click on it to open and it closes the program. Share this post Link to post Share on other sites
Xtremethrottle 0 Posted May 5, 2009 Yes i do know how to use the import feature. Like i said im not knew to doing this kind of stuff just this program. It just does not make any sense why i cant open any files. Forget trying to cut something with it. At this point i would be happy if i could just get a file to open. but if i cant figure it out by tomorrow im just going to get a version of Flexi and hopefully have better luck with that. Share this post Link to post Share on other sites
pogo 0 Posted May 5, 2009 More than likely the ai files you are trying to import are a newer version than Signblazer can read. Share this post Link to post Share on other sites
Xtremethrottle 0 Posted May 6, 2009 Thank you very much. I bet that is exactly what it is. Im using CS3. Is there anyway i can save it as a older format just like with AutoCAD? Share this post Link to post Share on other sites
Jay2703 704 Posted May 6, 2009 Yes, if you save to .eps it will ask you what version to save to. Share this post Link to post Share on other sites
