dalen2k 0 Posted September 4, 2007 I am using Corel x3 and signcut-x2. I have designed a sign that is 14wide by 24high. When I send it to signcut, no matter what direction I have the degrees set to it always wants to cut the width of the vinyl and not the length of the roll. I am using 15 inch wide vinyl. I have made sure the x and y is set in signcut as well as the degrees for the direction of cut.The main file is set to portrait in Corel and when i preview it in signcut, it look correctly on the vinyl. Please help Share this post Link to post Share on other sites
kenimes 42 Posted September 4, 2007 Instead of using the degree setting, use the rotate image tool in SignCut. It is the little red arrow that points down and once you click on it, you get the rotate tolls at the bottom of the screen. Use these to rotate your image the way you want it cut. Share this post Link to post Share on other sites
