hbgsigns 0 Posted August 28, 2007 I set up the copam 24 and had no problems communicating between the computer and the plotter using Corel but just this morning when I pulled the file which I convert to Adobe and place it on the desktop then open it from signcut from the desk top. It will open up but when I hit the cut button a screen pulls up to save as with the only file is a plot file to save it in. this never happened before and I can't get it to cut now. I need help with this. 717-571-3333 Dan Share this post Link to post Share on other sites
West Wood 0 Posted August 28, 2007 This sounds like what happened to me last week. You should be able to go to your SC x2 Settings and change from save as to the correct port you are using. That's what I did. Good luck! Share this post Link to post Share on other sites
kenimes 43 Posted August 28, 2007 In SignCut, click Settings, then Cutter, and make sure your Device is set to the correct COM port instead of Write to File. Share this post Link to post Share on other sites
