fluffer 0 Posted April 16, 2009 Just got my new Graphtec, so far I love it. One problem I have is that when I do large cuts, the edge of the left side never gets cut, it just acts like the rest of what it is suppose to cut is not there, almost like some kind of margin issue...Anybody have any tips? Share this post Link to post Share on other sites
Renegade 2 Posted April 17, 2009 I've had that when I get my graphic a little to big for the actual cuttable width, but normally I know that has happened when I look at the weed lines and such on the screen or when I get the edge of the cuts that should have been there farther up the material. Best thing is to use the poll size button and then you can compare your image size to your cuttable width and make sure its slightly less. Share this post Link to post Share on other sites
racinboy30 9 Posted August 1, 2009 If your using signblazer in your cutter interface ( where you select and apply cut) in setting change the width of your vinyl to 24 or 30 or whatever your cutting so that it knows how wide the vinyl is. Length doesn't matter unless its setup at like 48 inchs, i just set lenght to like 10 ft. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 1, 2009 I'm not partically joyful about the way that works myself, as I think it wastes too much vinyl, but what are ya going to do?? What ya going to do? Go into background settings and disable it... I never use it, just one of those frills that I just don't use. Share this post Link to post Share on other sites
Brandon_Davis 1 Posted August 1, 2009 Learning to manipulate a graphtec to effeciently uttilize vinyl only gets better with experience! Share this post Link to post Share on other sites
