biggin69
Vinyl not tracking straight...Please Help...
I have an LP 24". I am attempting to cut some racing stripes for my truck. When I cut them, they started of 11" wide on one end and ended up being about 7" wide on the other. Thay are 70" long. How do I make my vinyl trak straight? Thanks in advance! :thumbsup:
You might look at calibrating your X and Y, there is a sticky on this subject, I believe.  Also, be sure to ground your cutter, using the info found around here.
This isn't a problem of vinyl tracking, its a problem with the cutter tracking.  If the vinyl was off, the stripe would be 11" wide all the way, it just wouldn't necessarily be parallel to the edge of the vinyl.
