scandalous
SOLVED - Need Laserpoint 24" Driver
So I just got my 24" LP today and got everything set up. I tried to install the drivers but apparently the Banana Digital disc is empty, my computer, laptop and Mac all say it's an empty disc.
Currently if I plug in the LP my laptop picks it up as my race cars ECU system (Hondata).  :thumbsup: LOL
Is there somewhere I can download the drivers? (I am running vista by the way)
Thanks in advanced.
Oh and just wanted to make sure on one thing. I have used nothing but Roland machines in the past so I have been spoiled with the features they have. I figured out the LP needs to have the material manually imputed, but do you need to manually cut the material when your done? In other words it doesn't have a blade that cuts the piece of material off correct?
Thanks again.
Nope it doesn't cut it off for you. Does have a nifty little slot in the front edge that works pretty good as a guide, but you'll be covering that up with a piece of tape soon to avoid getting your vinyl snagged.
Just a good ol pair of scissors is what i use.
Thanks Blues for the link.  :P
I still could not get it to work. The computer would not recognize the LP. Don't have a serial port so that was not an option.
I consider myself very computer savvy, but this kicked my butt all day.
Anyway, after almost giving up I decided to download Signcut and the drivers for my Mac running 10.5.6 and got it to work within 15-20 mins!!! Did some test cuts and everything came out perfect!
sarconastic, thanks for the slot suggestion. I did not notice it and was using scissors until I read your post. The slot worked good with the exacto.  :thumbsup:
