Junkman 0 Posted April 5, 2009 When I convert a bitmap to monochrome and then vectorize it flips the image. Any suggestions or is this normal. Also how to I seperate the bitmap from the cutable image? Thanks Share this post Link to post Share on other sites
aries58 0 Posted April 5, 2009 When I convert a bitmap to monochrome and then vectorize it flips the image. Any suggestions or is this normal. Also how to I seperate the bitmap from the cutable image? Thanks I would uninstall,then reinstall see if that helps. separate top one by moving to the side, it should be the vector delete the one left move one you moved over to side back and it should be the vector one.hope this helps.. Share this post Link to post Share on other sites
Junkman 0 Posted April 5, 2009 ok thanks I will try that Share this post Link to post Share on other sites
mb20music 760 Posted April 6, 2009 you should get Inkscape for vectorizing, it does a much better job than signblazer. Share this post Link to post Share on other sites
Junkman 0 Posted April 6, 2009 where can I get Inkscape? Share this post Link to post Share on other sites
CyberChuck 4 Posted April 6, 2009 http://www.inkscape.org Share this post Link to post Share on other sites
